Wiring Diagram for 1974 Carver Santa Cruz
- ptnicholas59
- Vessel Info: I have a 1974, Carver Santa Cruz I believe.
- Has thanked: 1 time
I am new here, so I'll do my best to adhere to protocol.
I am in the very long process of restoring a 1974 Carver Santa Cruz. It seems to have an electrical issue which led me to looking for the production wiring diagram. So far with no luck. Can someone tell me if the wiring diagram is available and if so how to get it?
Thanks all PT
Re: Wiring Diagram for 1974 Carver Santa Cruz
What type of an issue are you having? I'd bet most of that wiring is typical of the boats of that vintage, not just unique to Carver.
- ptnicholas59
What engine package do you have? A lot of times, any circuitry information/diagrams related to the engine and instrumentation can be available from the engine manufacturer. Mercury/Mercruiser for example is easy to get.
There are a few diagnostic procedures that we could guide you through if you provide some more detail and are willing to do a little work yourself. Could your mobile guy not figure out where the fault was? The momentary switch isn't the answer, problem still exists.
- What was checked, and what possible faults were eliminated in the process?
- Ignition switch is okay?
- Wiring harness plugs and connections are okay?
- Is there a slave solenoid was it checked?
- Neutral safety switch is working properly?
- Where was this temporary switch installed, and was it done safely or can you start the engine in gear?
The power draw can be a number of things but a simple test meter and isolating each circuit would lead you to the circuit that's at fault. If you have an electrical panel with breakers or fuses, this might make it easier. If you have any loads by-passing the distribution panel and going directly to the batteries, first, this is a no no but you can disconnect those first to see if that parasitic draw disappears. You may also want to test your batteries properly to ensure it's not a battery issue before you assume it's a ship's wiring issue.
The above is just a primer but a place to start. The guys are a good bunch here so I'm sure you'll get some good feedback along the way.
