Heat
- Been thanked: 490 times
Re: Heat
Have no idea what ac system you have. On some, heat must be selected. Do you have the manual? If not, you should be able to find one on the net.
Good luck.
Re: Heat
Also, if they are reverse cycle heat, you may not get a lot of heat if the outside water is very cold. Some units have supplemental heat because of that issue, which is a little additional electric space heater built inside the unit.
- Has thanked: 602 times
Re: Heat
As with most of these units, it is usually not advised to run the heat cycle when the surrounding water temp is near 40 Degrees F and below that....
Re: Heat
These systems are not meant to be run when the your boat is floating in is below about 40 degrees.
You need to flush and winterize the heating and water systems or you will have a very unpleasant spring $$$$$$$$$.
