Bilge Fans - independent or ganged
weatherorknot
Topic author - Scurvy Dog
- Vessel Info: 2000 396 AC
I have a newly-acquired 2000 Carver 396/Diesel, and was only able to obtain the owner's manual for the 2002 model (from Carver), with a note that not much/if anything changed between 2000-2002. My question is about the Bilge Fans.
There are 4 separate bilge fans, each with their own circuit breaker. There is also a "bilge fan master" switch. Curiously, though, the 4 bilge fans are not wired independently, but rather ganged through fan #1 (i.e., fan #1 has to be on to allow any fan to be on). To be sure I'm explaining this well:
* With the Fan Master "on", and all 4 Bilge Circuit Breakers "off", no fans run. As expected.
* With the Fan Master "on", and only Fan #1 Breaker "on", then only number #1 fan runs. As expected.
* With the Fan Master "on", and only Fan #2 Breaker "on", **NO** fan runs. This is also the case for fan #3 "on" or #4 "on". This seems strange, because the fans would seem to be independent of one another. The wiring diagram in the owner's manual (different year), shows the fans as independent.
* With the Fan Master "on", and Fan #1 "on", and Fan #2 "on", then **BOTH** fans run. This is expected, but in contrast to the point above, it indicates the fans are ganged through Fan #1.
* Obviously with the Fan Master "off", no fan runs. With the Fan Master, what would be the value of ganging the fans through Fan #1???
The issue is that the Fan #1 circuit breaker has to carry the load of all 4 fans (because of the ganging), and it pops when all four fans are running. Any combination of 3 fans (e.g., #1, 2, 3, or #1, 2, 4, etc...always requiring #1 to be on), will run without problem.
Before I re-wire this back to having the fans independent, I wanted to check to see if there is any reason for the ganging, or if there folks that have similar ganged wiring.
--Jim
2000 Carver 396 ACMY, Diesel/Cummins
Home Port: National Harbor, MD
weatherorknot
Re: Bilge Fans - independent or ganged
Just to let you know what I found out about this. The fans are not ganged, each having own independent power. However the power from Fan #1 activates a relay on all of the fans to allow the master fan switch to work. So, Fan #1 needs to be on to allow any fan to be on, but not all power is running through the Fan #1 circuit.
Happy boating!
--Jim
- Been thanked: 654 times
Posting the solution serves to help everyone. It's unfortunate that folks take time out of their day to respond to an inquiry in an effor to help someone, only to be left hanging, never knowing if their's or others' suggestions did the trick, or if something entirely different worked that we could all learn from. So for that, I too thank you for keeping us in the loop! Now we all know.
- Been thanked: 491 times
- Hugo
- Has thanked: 2 times
- Been thanked: 23 times
We have a switch on the helm to turn the blowers on/off and the only thing I figure that is for is to turn the blowers on after the ignition is off which you can also do from your DC control panel with a switch. When running the boat there's no control over the blowers with the helm switch.
I will probably remove the ignition feed that turns the blowers on so that the switch on the helm can be used to turn the blowers on/off...
My guess is it's wired this way for models that may have gas engines... Mine is a 444 which only comes in diesel but since it's an extension of the 396 the wiring is probably the same.
- CYO Admin
- CYO Administrator
- Has thanked: 269 times
- Been thanked: 29 times
- voyager57
- Vessel Info: 2002 57' Voyager Pilothouse
- Been thanked: 2 times
Has anyone put in a separate manual on/off switch to accomplish this? I’m not an electrician and don’t want to start messing with the wires going to the ignition, but think it can’t be that complicated. I also have an upper and lower helm so am unsure if that complicates the issue. The starboard ignition from either station activates the blowers, so am unsure if they are wired in parallel or are separate going to the engine room. Any help is much appreciated!
- Hugo
Carver may be able to provide a schematic of how it's wired if you call them.
In a nutshell there are relays near the blowers. One side of the relay is going to be the load side with heavier gauge wires and that will go to the breakers. On the other side of the relay, the signal side is where your signal would come in to energize the relay from a switch for example. It can be figured out with a meter but will be easier if you get a schematic.
- Lyndon670
- Has thanked: 124 times
- Been thanked: 140 times
On mine, the "other" DC panel (that Hugo speaks of) is on the aft bulkhead going into the engine room. The switches for all the blowers, windlass, bow thruster and charger on this panel.
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
