De-icer
- tgebler
- Vessel Info: 2000 396 AC
- Has thanked: 5 times
- Been thanked: 29 times
De-icer
Also, I have been looking for a used de-icer with no luck. Any thoughts in that regard?
Thanks.
- Phrancus
- Has thanked: 16 times
- Been thanked: 136 times
- Contact:
Re: De-icer
Over here (Europe) there is a shift going on from lifting and storing ashore towards leaving in the water over winter. However, our energy prices are much higher over here then on your side so it takes something clever to get the job done as economical as can be...
Re: De-icer
Some also use bubblers for the same purpose. Just air hoses run around the boat laying on the bottom that bubble air up to the surface continuously, bringing that warmer water with it too.
- uchu
- Vessel Info: 1988 Carver Santego 2767 - Twin Mercruisers 4.3LX with Alpha-One drives
- Has thanked: 86 times
- Been thanked: 15 times
Re: De-icer
Phrancus wrote:Source of the post A noob question: what is a de-icer? (yeah, I know from the words what it does, just curious what devices you use on your side of the big pond to keep a boat frost-free)
It's basically a motorised propelling device that allows fast water recirculation, thus preventing ice formation at low temperatures.
- Been thanked: 491 times
Re: De-icer
Will insurance cover it, have you declared it will be stored in water?
Re: De-icer
I never have left mine in the water. I could never see the benefit. It costs about the same to leave in as it does to haul out and relaunch in this area.
You still have to winterize everything, so you cant actually use the boat. and then you have to worry about water freezing into your inlet through hulls.
I would be worried about it all winter.
- Phrancus
- Contact:
Re: De-icer
