Access to sea strainer
Roddono
Vessel Info: 1991 Carver 33 Aft Cabin
Has thanked: 26 times
Postby Roddono » January 21st, 2021, 10:50 am
Anybody have any suggestions on how to get to the starboard sea strainer on a 1991 Carver 33 aft cabin? I can see it, it is under the dinette but now way to get there. Access panels under seat cushions go nowhere. Thanks in advance.
Ray...
Roddono
Re: Access to sea strainer
Postby Roddono » January 21st, 2021, 11:32 am
Roddono wrote:Source of the post Anybody have any suggestions on how to get to the starboard sea strainer on a 1991 Carver 33 aft cabin? I can see it, it is under the dinette but now way to get there. Access panels under seat cushions go nowhere. Thanks in advance.
Ray...
Also I forgot to add I have crusader 454 engines. I have read some posts that those engines for that year might not have had sea strainers so the one on the port side I cleaned might have been a/c and the one on starboard side I can’t get to might be generator. Any thoughts on this as well?
Ray..
Postby Viper » January 21st, 2021, 11:50 am
That's correct, not all of the earlier models had strainers. For those that did, and I might be thinking of the 35's, I seem to recall that if I couldn't squeeze down there from the top in front of the engine, I would get in front of the port engine and access the starboard strainer by stretching across the front of the generator. And yes, typically the AC strainer was on the port side and generator strainer was on the starb side.
Roddono
Postby Roddono » January 21st, 2021, 11:54 am
Viper wrote:Source of the post That's correct, not all of the earlier models had strainers. For those that did, and I might be thinking of the 35's, I seem to recall that if I couldn't squeeze down there from the top in front of the engine, I would get in front of the port engine and access the starboard strainer by stretching across the front of the generator. And yes, typically the AC strainer was on the port side and generator strainer was on the starb side.
I did not think of that. I will try. Thanks
Ray...
Roddono
Postby Roddono » January 21st, 2021, 2:17 pm
Worked! Little tight, carrying a bit of holiday weight.
Thanks.
Ray...
Ray...
Postby bud37 » January 21st, 2021, 3:33 pm
While you are at it, you could make some spare gaskets for the strainer lids and hang them down there in a zip lock....ya never know...
Postby km1125 » January 21st, 2021, 4:10 pm
Did you figure out if it's an engine one or one for the generator? I would think they'd be easy to tell apart, as the engine ones should be at least 1 1/4" hoses.
I would be miffed if strainers or seacocks were tough to get to. I think you'd want EASY access to something like that, even if another hatch had to be put in somewhere.
Postby Viper » January 21st, 2021, 10:17 pm
Glad it worked out. Do you have engine strainers?
Roddono
Postby Roddono » January 22nd, 2021, 9:00 am
km1125 wrote:Source of the post Did you figure out if it's an engine one or one for the generator? I would think they'd be easy to tell apart, as the engine ones should be at least 1 1/4" hoses.
No engine strainers. One for a/c and one for genny. They are different sizes. That should have been my first clue. And yes, a separate hatch would be nice.
Ray
Roddono
Postby Roddono » January 22nd, 2021, 9:01 am
Viper wrote:Source of the post Glad it worked out. Do you have engine strainers?
No. Just genny and a/c.
Ray...
