We decided to start out by assembling the stairs on the ground. It took about an hour to get the bottom step on and aligned. Thankfully the other three stairs went on in about 5 minutes each. Next step was to remove the old ladder. What a chore that was. So, now we have a spiral stair case to nowhere and no ladder to the deck!! We have to now figure out how to remove the brackets that were holding the old ladder. The screws are just spinning. We assume that the brackets are maybe glued on as well as the screws. Any thoughts on how to remove them. Can't dry fit the new stairs until those have been removed. Won't get back to the boat for a couple of weeks so it will give us time to research that. As well as fixing the screw holes.Welcome to Carver Yachts Owners Forum
Spiral Stairs - the long and winding ......
- Grafunkus
- Captain
- Vessel Info: 1982 33' Carver Mariner
1985 3607 Carver Aft Cabin - Location: Manitoba, Canada
- Has thanked: 63 times
- Been thanked: 32 times
We decided to start out by assembling the stairs on the ground. It took about an hour to get the bottom step on and aligned. Thankfully the other three stairs went on in about 5 minutes each. Next step was to remove the old ladder. What a chore that was. So, now we have a spiral stair case to nowhere and no ladder to the deck!! We have to now figure out how to remove the brackets that were holding the old ladder. The screws are just spinning. We assume that the brackets are maybe glued on as well as the screws. Any thoughts on how to remove them. Can't dry fit the new stairs until those have been removed. Won't get back to the boat for a couple of weeks so it will give us time to research that. As well as fixing the screw holes.- km1125
Re: Spiral Stairs - the long and winding ......
- Grafunkus
- Captain
km1125 wrote:Source of the post I think those brackets are through-bolted with backing plate inside. You might have to pull some of the carpeting off the walls. I think the lowest ones you can get to through the cabinet in the aft cabin ( port side) but the upper ones would probably require the carpet to be pulled away. You might be able to just cut a slit in it though, just to get to the nuts, and then use some carpet tape to put it back when complete.
Thanks for the input. That was our worst case scenario.
- Grafunkus
- Captain
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
Greg
- Been thanked: 654 times
- Grafunkus
- Captain
Nope, no pressure!!
Users browsing this forum: stach454 and 30 guests
