New member, shopping for my first Carver
Re: New member, shopping for my first Carver
The engines / transmissions and other mechanicals are your high priced "gotcha" items. This is especially true on an aft cabin boat because labor to replace an engine can be twice what it would be for an express cruiser, due to access issues. A surveyor will only look at the engines and monitor temps, pressure and performance. This will find any glaring problems, but is no guarantee of internal condition and "life left".
Structure is the next biggest issue. If your looking at a Carver into the 1990's or newer you shouldn't have to worry about stringers, which can easily cost more than the boats value to replace, but bad decks can be expensive too. These items will or should be identified by a good survey.
- Has thanked: 603 times
May I also suggest you read thru as many of the threads on this forum about repairs etc, there is a lot to be learned from just doing that. Many different Carver models are represented in those threads with some great info and insight from experienced owners. Much of this info applies to other makers boats as well....Again good luck with your search.
