Blowers are not working 405
- Serendipity
- Vessel Info: 1998 Carver 405
- Has thanked: 234 times
- Been thanked: 38 times
Now I get nothing and this is what I have tried so far. Boat is a 98 Carver 405 and new Rule bilges and blowers were installed 2 years ago and 100 hours ago.
So I initially checked the blower switch on the helm, only 1 helm by the way. It has continuity, but to double check my multimeter. I swapped it out with the forward bilge switch and I could hear the bilge come on. So the switch is testing good.
I had to leave tonight but I am going back in the morning to test the continuity of the blowers at the blowers. At least I will know if they are getting power.
I read someone that a fire protection system could turn them off on some boats?
I only have a cannister and no gauges on the fire cannister bottle. Just wondering if there is a work around here if this applies to Carvers.
I have turned all the breakers off and back on in the dining room panel. I did not see a breaker specifically for the blowers, but bilges yes.
Could it be a bad breaker? How do you test a breaker in the panel? Do I have to remove the panel to test from the back side? I would surmise yes.
I researched the 200 comments posted but did not find any answers.
Any thoughts on what to test or try next guys?
- Been thanked: 654 times
Re: Blowers are not working 405
- Serendipity
That is an awesome idea and thanks. Sometimes I forget about those breakers not using the boat very often.
The green light isn't on, so it very possibly could be a thrown breaker my friend and the switch did work on the swap out.
Thanks again for that reminder
Michael
Thanks for the follow up g.g36 wrote:Source of the post Hi Viper there's no breakers like that on the upper helm on the 405/406....
- Serendipity
So I did check the switch with a new multimeter and it tested good. Then to double check the switch, I swapped the switch with a known good bilge switch. So the blower switch is working.
I installed a new battery last fall and my other batteries are 2 years old. Both engines fire and start immediately, but I haven't checked the batteries for output. So that is a thought
I cut the wires leading to the blower behind my port engine to see if the blower would power up with a dual jumper wire connection to a battery. I test the connection on both engine batteries and the blower did not spin up.
So my wife and I took her 90 year old parents to church today in Mobile Alabama for Easter. While we were there, I picked up 2 new 4 inch blowers made by West Marine.
My goal is to install one of the new blowers on the jumper wire setup I have and see what happens.
I also need to get my multimeter in the engine compartment to see if power is getting to the blowers.
Regardless, I am replacing the blowers as it sounds like they could have burned themselves out. I will be heat shrinking the connections as well.
All breakers under the stairs are showing good with no issues. Breaker panel in the galley shows good as well, but it may be time to replace those breakers since they are 20 years old.
So where would your source be for those breaker replacements?
And I will update ya if the blowers correct this issue.
Next up, replace the vacuflush units are they are leaking down.
Then the Norcold fridge was 3 months old when I purchased the boat in the summer of 2018. It works when it wants too. So it will be coming out to trouble shoot it.
A labor of love at this point
Also vacuflush unit leaking down will most likely be an easy fix. If its building vaccumm and leaking it's probably the duck valves ir if not holding water in the bowl its most likely the seal there. Both are easy enough on our model to get to and swap.
My oem norcold got replaced with a vitrifrigo unit. It's way better than the norcold ever was. The swap requires a slight bit of trimming the cabinet and a 1" spacer around the frame. It's a great fridge.
Users browsing this forum: Google Adsense [Bot] and 16 guests
