Blowers Suck!!
Blowers Suck!!
Not exactly cheap at $60 but does look rather promising. https://www.aliexpress.com/item/4000572 ... oKoEh&mp=1
Do need to verify it is actually 12v as further down in the description it says 220v.
- Phrancus
- Has thanked: 16 times
- Been thanked: 136 times
- Contact:
Re: Blowers Suck!!
Something like a computer ventilator, brushless and magnetic 'bearing' would suit my purpose.
Which is why I write this: perhaps there are brushless ventilators in the size you need as well.
Re: Blowers Suck!!
Re: Blowers Suck!!
- Has thanked: 602 times
Re: Blowers Suck!!
Viper wrote:Source of the post Of course having said that, they don't build things like they used to
Ya mean more like this......
Sorry Hans , now that is a the real badass blower....
Re: Blowers Suck!!
Re: Blowers Suck!!
That's what I'm talking about. Just make sure you fasten everything down in the engine compartment Hansbud37 wrote:Source of the postViper wrote:Source of the post Of course having said that, they don't build things like they used to
Ya mean more like this......![]()
- Phrancus
- Contact:
Re: Blowers Suck!!
Re: Blowers Suck!!
Should be almost dead silent which is the goal but will only produce 70cfm compared to what seems to be a standard 130cfm. In my case I have 4 blowers in the bilge and do not see any issue with a little less flow. As much as I hate to admit it, the existing ones are not even being used as they really create a racket, they drown out the sound of the generator.
Planning on hooking them all up to function either when engines are running or generator is in use. The huge vents on each side of the 41CMY really allow lots of air into the engine compartment. So much so that if it the wind is broadside it is actually windy in the bilge.
Re: Blowers Suck!!
