Blowers Suck!!
- Been thanked: 654 times
Re: Blowers Suck!!
Re: Blowers Suck!!
Viper wrote:Source of the post I know you have a diesel application but a non-marine rated blower might end up being a red flag on the next survey. You should call a surveyor and discuss.
I already know the answer he will give me. I'll just keep the old getto blasters and pop them back in if I sell the boat. May even take the time to disassemble them and change bearings
- Has thanked: 602 times
Re: Blowers Suck!!
Funny this never dawned on me after all these years until this thread, I would just go down and put my hand over the vent......hmmmmm...
Re: Blowers Suck!!
I was inspired by the BadAss unit linked to in post number 3 of this thread. 3D printed the adapters for 120mm fans which are available by the hundreds as this is standard sizing for these units. Found a 12vdc unit that produces 200 cfm @ 1.6A in a brushless design. I did try with a 130 cfm almost silent fan however I did not like the output. that fan can be seen in the picture against the wall and may use it to promote better air circulation behind the boat fridge to improve efficiency. The fan I chose produces the equivalent or better than the typical Marine inline blower. I doubt I will ever need to change a fan however they are easily replaced by just removing the stainless screws holding it all together. I would say about half the noise of your typical blower, probably less. Will evaluate once installed in the boat and functioning. Have not finished the attachment bracket yet, basically a piece of thin aluminum angle, once again inspired from the BadAss model OR I may just use a piece of hanger strap which will do the job as well but not look as nice.
Fan. https://www.amazon.ca/gp/product/B07F7Z2YCM/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
3D Adapter File. https://www.thingiverse.com/thing:1163183
Used Stainless Steel M4 x 16mm nut and bolt assembly x 8 with washers/lockwashers. total cost for 1 unit for all materials was about $35 CDN.
I call this the "Badder than BadAss MidnightSun Special" or BBMS if you prefer
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
Re: Blowers Suck!!
Re: Blowers Suck!!
Once you put any type of ducking to or from them them the air flow will drop from 200 cfm to to almost zero.
Bilge blowers are noisy, because they can move air and over come the high static pressure of the flexible duct.
Re: Blowers Suck!!
This clip will give you an idea of how much air this unit can push. Far from you average little computer fan that puts out a slight breeze. Heck, may even have a Tesla motor in there.
https://www.amazon.ca/images/I/61A6Xk5IvnS.mp4-
Re: Blowers Suck!!
Re: Blowers Suck!!
