1995 355 WATER HEATER ISSUE
seldomdry
Vessel Info: Seldom Dry
1995 355 AC
St. Croix river Stillwater MN
Postby seldomdry » April 29th, 2021, 11:12 am
I need to replace water heater. Problem is it is mounted under the dinette. It will not fit through the floor access panel.
Help!
Re: 1995 355 WATER HEATER ISSUE
Postby km1125 » April 29th, 2021, 11:28 am
I don't know if it was the same model, but I think there's a thread here where someone took the casing off so it would fit through the access panel.
Are you 100% sure it's defective enough to warrant replacement instead of repair?
Has thanked: 474 times
Postby Viper » April 29th, 2021, 6:10 pm
Ya it'll come out. I've never had to do it but I believe the thread KM is referring to is the one where the owner cut a couple of slots on the side of the hatch opening just enough so the mounting tabs on the tank would fit through the hole if I remember right. Not an easy replacement for sure but ya, like KM said, unless the tank is corroded and leaking, I would repair rather than replace.
Been thanked: 248 times
Postby mjk1040 » April 29th, 2021, 6:15 pm
Check under the bench seat over the hot water heater I think there's an access panel there, but may not be any bigger than the floor panel under the table. In that case you may have to disassemble it as km said and hope the replacement is more compact and will fit back in thru the floor panel.
Postby Viper » April 29th, 2021, 6:26 pm
The access in the bench is too small. You can use it to access the fasteners but that's about it.
DanM
Vessel Info: Carver 396
Been thanked: 35 times
Postby DanM » April 30th, 2021, 9:34 pm
SeldomDry,
On the 2001 356 I had, the WH had developed a leak believed to be created by a detached grounding wire. The hatch with a 1"x 1" notch cut in the hatch seating lip was the exit point. I wish I could find the pictures but so far no luck.
There was no way it would come out without the 1"x1" v-shaped notch. When the hatch was in place the notch was covered. Good luck!
Dan
Carver 396
SugarSand Tango
Postby Viper » May 1st, 2021, 7:42 am
Here is the thread showing the cut outs to get the water heater out of the hole:
https://www.carveryachtowners.com/viewtopic.php?f=13&t=5680&p=44440&hilit=water+heater#p44440
Users browsing this forum: No registered users and 49 guests
