Hello/ New here
CaptDenny
- Vessel Info: 1998 Carver 405
- Been thanked: 2 times
Hello/ New here
Port engine ran hot coming from having it pulled for bottom painting. Found the impeller Shot with all the fins off. Out of my pay grade to finish it up right. Hired the local engine guy and he ended up needing to remove a motor mount to pull the water pump and after cooler and by doing this the shaft must be disconnected from the transmission just to be sure that it won’t get bent. I have read that Cummins should have thought this through before putting the motor mount THERE. Anyone else run into this?
- Been thanked: 491 times
Re: Hello/ New here
I can't finger Cummins on this. They just built the engine. How it's mounted is on Carver. My two cents.
- Been thanked: 654 times
Re: Hello/ New here
Re: Hello/ New here
I've had to get into some pretty tight spots and do some dismantling to get to water pumps but I've never had to go as far as removing an engine mount.
