Charging on Alternator
- vickyb
- Has thanked: 3 times
When I have the Shore power connected: Batteries are at 13V
With Generator: 13V
With Alternator: 12V and steadily drops to 11.5 no matter what the engine RPM. All DC house systems are turned off, especially the refrigerator
I checked the breakers on the Port Side aft wall (where the orange wires come in from the alternators and they are good. Checked the output from the Alternators with the engines running and it is 14.2V.
Really confused with this. Is this normal?
All batteries replaced last week.
Volvo Penta Model 8.1Gi
length - 42'11"; beam - 13'5"; draft - 2'7"; displacement - 26,000 lbs.,
Overall length of the vessel: 44'6"
Re: Charging on Alternator
I will double check but I remember ( foggy at best
) some switches on the breaker panel in our old boat and the battery switch position changed things at the helm readouts.- vickyb
Also sounds like your house batteries are probably weak. How long does it take for them to drop to 11.5V and what do you have running on them at the time?
- vickyb
- Has thanked: 474 times
I assume this is with no shore power hooked up or generator running (charger non-operational)?vickyb wrote:Source of the post.... With Alternator: 12V and steadily drops to 11.5 no matter what the engine RPM. All DC house systems are turned off, especially the refrigerator....
- vickyb
I will troubleshoot as per your suggestion above. Thank you
vickyb wrote:Source of the post My main concern are the two engine batteries that drop in power. House and Generator batteries are fine when alternator is on. The two engine batteries (also brand new) are the problem.. they drop to 11.5 volts (port) and 11.8 (STB) in about 2 hours of running. As indicated on the dashboard panel on the bridge
That is why I asked if you had checked the voltage directly on the sets of battery terminals themselves with the engines running.....
Users browsing this forum: No registered users and 48 guests
