Crusader 350 XL Alarm Beep Interpretation
- Thekaj
- Vessel Info: 1995 325 Aft Cabin
- Been thanked: 4 times
All the gauges, oil pressure, water temp, voltage, were showing just fine on both engines, and the boat wasn't acting any differently. This was over a 2.5 hour trip, where I kept the throttle at around 2,600 RPMs. So definitely not pushing it. It even happened again when I was running at near idle speeds in a no wake zone.
I'm hoping that the 8 beeps means that's a specific code, just like different beeps on a PC will point to a specific error, but am I just dreaming that up? I've been trying to Google an answer myself, but have come up empty. These are carbureted engines with no way to plug in and get the error code.
Anyone have any thoughts on what my boat was trying to tell me?
Re: Crusader 350 XL Alarm Beep Interpretation
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
- Has thanked: 603 times
But I would expect to hear that any time, not just when the boat is running unless you had CO in the cabin which is possible.
- Thekaj
I am starting to lean towards the fire suppression system though. That gauge is in the same area as where the alarm was coming from, and a low pressure alert was one suggested cause that I came across in my Google search. There is a light on that gauge, which wasn't going off when the alarm was, but at 26 years old, who knows if that would even work. That should be an easy enough think to poke my head in the bilge and look at the gauge on the tank.
Still on my to-do list this season is an oil and transmission fluid change. So those things are already on the list of things to deal with anyway. Thanks for the suggestions!
- Thekaj
It didn’t go off at all the last time we were out. The coolant had been low, so I had filled that, and assumed it was a temperature related issue, despite the gauges reading fine. But today it started going off like crazy as we departed the busy waterway, then went silent as we got out to open water. Suddenly went off again when a sailboat started to cross in front of me, and lightbulb went off in my head. Confirmed it when it happened again when a ferry crossed in front of me.
The weird thing is this just started this year. I must have reset a setting in the off season. One I am definitely going to reset again now!
Oye, there’s really nothing like an unidentified alarm to make you dread taking your boat out. Thanks for the suggestions!
