Electrical problem with refrigerator, lights , radio
Annie429
Vessel Info: Caver Yacht 44. Year 2004
Postby Annie429 » June 6th, 2021, 8:59 am
We have a carver 444. We have a 50 am plugged in with splitter. When plugged in at dock there is no electricity going to refrigerator, cockpit radio, and some lights. When we took the boat out the bow thruster wouldn’t turn on. Assuming there is an electrical issue. Any idea how to trouble shoot? We did try turning generator on to see if that would work but it didn’t. Thanks!
Re: Electrical problem with refrigerator, lights , radio
Postby Midnightsun » June 6th, 2021, 10:22 am
Plugging in to shore power will not turn on any of those items except the fridge assuming it is dual voltage. Fridge, lights and radio are 12v. Sounds more like the house bank selector switch is off or some 12v breakers are off.
Welcome to CYO. :captain2:
Postby Viper » June 6th, 2021, 11:06 am
Is the charger on and charging? Could be a number of things but I'd start with checking charger output and testing all your batteries, and check battery connections to ensure they're clean and tight.
Postby bud37 » June 6th, 2021, 2:35 pm
Annie429 wrote:Source of the post We have a carver 444. We have a 50 am plugged in with splitter. When plugged in at dock there is no electricity going to refrigerator, cockpit radio, and some lights. When we took the boat out the bow thruster wouldn’t turn on. Assuming there is an electrical issue. Any idea how to trouble shoot? We did try turning generator on to see if that would work but it didn’t. Thanks!
Welcome to the forum.... One question though, did this just happen and was ok before ?
Annie429
Postby Annie429 » June 6th, 2021, 3:32 pm
This is the first time it has happened. We tested the batteries and replaced two of them and this seems to have fixed the problem. Thank you all for your help.
buster53
Vessel Info: 2001, Carver 356
Has thanked: 10 times
Been thanked: 285 times
Postby buster53 » June 6th, 2021, 3:41 pm
Annie429 wrote:This is the first time it has happened. We tested the batteries and replaced two of them and this seems to have fixed the problem. Thank you all for your help.
Good to know you found the problem, however…
Even if the batteries were toast, you should be able to run anything 12v with the battery charger turned on. Maybe check that out as well.
Postby bud37 » June 6th, 2021, 5:28 pm
I agree about the charger, check it out ....perhaps that killed off the batteries then died, hence your problem. Won't hurt to go thru everything carefully.
Return to “Electrical”
