2001 46 foot Carver aft cabin
1966billprice
Vessel Info: 46 2001 Carver aft cabin
Postby 1966billprice » June 6th, 2021, 11:02 am
I am looking to purchase a 2001 46 ft. Carver aft cabin. I need to run her up to Lake Champlain. During the trip we will need to go under two low bridges with a clearance of 17 feet 3 inches. This particular boat has a hardtop cover on the bridge. Does anyone know the measurement from waterline to the top of the hard cover?
Re: 2001 46 foot Carver aft cabin
Postby Viper » June 6th, 2021, 11:03 am
Welcome aboard. Hopefully someone with the same model will chime in.
buster53
Vessel Info: 2001, Carver 356
Has thanked: 10 times
Been thanked: 285 times
Postby buster53 » June 6th, 2021, 5:06 pm
Does the boat have anything mounted above the hard top like maybe a radar dome?
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 413 times
Postby Cooler » June 7th, 2021, 9:37 am
The 466 is 19' 5". The 444 is 18'. Both are 46 long so not sure which actual model you are referencing. 8-) er
https://carveryachts.blob.core.windows. ... cht_01.pdf
Cooler By The Lake
Been thanked: 470 times
Postby RGrew176 » June 8th, 2021, 7:46 am
Welcome Aboard. Good luck with your trip.
1966billprice
Postby 1966billprice » June 8th, 2021, 10:23 am
buster53 wrote:Source of the post Does the boat have anything mounted above the hard top like maybe a radar dome?
No just the hard top. I need the measurement from the hardtop to the waterline.
1966billprice
Postby 1966billprice » June 8th, 2021, 10:25 am
Cooler wrote:Source of the post The 466 is 19' 5". The 444 is 18'. Both are 46 long so not sure which actual model you are referencing. 8-) er
2001 Carver 466 Aft Cabin Motor Yacht is the boat I am looking to purchase. I can find measurements for the height of the boat on brochures but it is referring to the boat on a trailer on a highway. I need the measurement from the bridge hard top to the waterline.
Postby bud37 » June 8th, 2021, 11:59 am
My guess is you will have to physically measure it......no telling what is on top and the hardtop may be fitted differently, how the boat sits in the water....these are all factors to get an accurate to waterline measurement.....good luck with your purchase.
Been thanked: 491 times
Postby waybomb » June 8th, 2021, 12:33 pm
Welcome aboard!
I'll have to agree with bud.
ColRon
“Escape Plan”
Has thanked: 77 times
Been thanked: 157 times
Postby ColRon » June 8th, 2021, 3:23 pm
1966billprice, the specs shown under bridge clearance on the link provided by cooler are not highway bridge clearances, but your air draft or height above the waterline. Now as Waybomb and Bud mentioned it is best to actually measure you specific vessel, so that you get your actual height. As it may vary depending on how full your tanks are, how much stuff and weight you have added aboard. The specs in the brochures and spec sheets get you within the general range, but each and ever vessel will be different.
Ron
“Escape Plan”
Murray, KY
:usa:
