Leaking Oil from Upper Helm
- Raylap819
- Vessel Info: 1988 Carver 3807; twin GM 454s
- Has thanked: 26 times
Oil is leaking from the fly bridge. steering wheel. The oil leaks on the surface of the dashboard and appears to come from the shaft on which the steering is attached. Happens mostly after the boat has been navigating. No leaks under the steering mechanism and hydraulic lines. The Auto Pilot doesn’t engage. This is a new boat to me, purchased during winter months so no trials were done prior the purchase. Has anyone experienced this. Any help would be appreciated.
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
Re: Leaking Oil from Upper Helm
- Has thanked: 474 times
You have a shaft seal leak. Pretty sure they are Seastar 1.7 helms on my '89 3807 so you probably have the same units. Get the make and model to be sure and you should be able to get a seal kit for it. They're not that difficult to do but is a learning curve if you've never done one. There are videos on YouTube. If the fluid level has dropped too far, it could be the reason why your autopilot isn't working. Either that or you have a separate issue with pilot wiring, communication, or faulty hardware. Also, open up the pilot computer and check if the fuse is blown. What pilot system do you have? Can you steer the boat with the wheel right now?
- Raylap819
- Cooler
- Raylap819
- Has thanked: 603 times
It may say you can use atf in an emergency in the manual, on the other hand it may have originally come with atf installed, they have tolerances and seal specs, that is why different fluids although there seems to me to be no reason for sea star fluid to be soooo expensive......
- Cooler
