Hello
- Bilgewater
- Vessel Info: 78 Carver 3396 Mariner
- Has thanked: 2 times
Hello
Re: Hello
While it may seem that they're leaking from behind the frames, a lot of times they leak because the channels can't drain. This is usually the result of an accumulation of crud that once cleaned out usually cures the problem, so check that first before committing to removing the entire assembly to re-bed it. If the problem is drainage, you'll have the same issue after re-bedding. Having said that, re-bedding may be due as well for that vintage.
- Been thanked: 654 times
Re: Hello
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Re: Hello
- Been thanked: 491 times
Re: Hello
Users browsing this forum: No registered users and 49 guests
