Spiral Stairs - the long and winding ......
Grafunkus
Vessel Info: 1982 33' Carver Mariner
1985 3607 Carver Aft Cabin
Has thanked: 63 times
Been thanked: 32 times
Re: Spiral Stairs - the long and winding ......
Postby Grafunkus » May 4th, 2021, 8:36 am
km1125 wrote:Source of the post Looks good! I think that would have made a huge improvement in my old 3607. Nobody was comfortable on those stairs. I would also opt for a larger swim platform. The stock one is about the smallest usable one you could have.
As we were drilling the holes for the bottom, Doug noticed that it seemed wet. We will be looking into a new swim platform next season. And yes it would be a little larger.
Postby Viper » May 5th, 2021, 7:03 am
Grafunkus wrote:Source of the post
Viper wrote:Source of the post Nice :down:
Do you find the height from one step to another an easy climb?
The height of the steps is a little steeper than I would like but they are much easier to deal with than the ladder. I did mention that to John (Stainless Outfitters). He mentioned that if they added more the treads would overlap too much. Also that the swim platform is installed after production and apparently there is no standard height.
Is each step thru-bolted through the post, and if so, were those holes pre-drilled? My thought is that if they weren't, you could set the steps closer together by dropping them all to a comfortable height because it's not currently a full step height from the top step to the deck. If the post came pre-drilled, I think I'd be drilling new holes to accommodate a more comfortable climb. This may not be doable in some applications but it's clear that there is room for adjustment in your case.
Grafunkus
Postby Grafunkus » May 6th, 2021, 8:35 am
Each step came predrilled with thru-bolts.
jjcaudle18
Postby jjcaudle18 » June 14th, 2021, 7:06 pm
can you tell me where you purchased the spiral stair case?
Users browsing this forum: geo and 15 guests
