3607 Carver 1989 18,500Lbs - how far driving on one engine?
- stutting
- Vessel Info: 1989 36ft AFT Cabin
- Has thanked: 8 times
Princeton Iowa
1989 Carver 3607 - Dual Mercruiser 454
Re: 3607 Carver 1989 18,500Lbs - how far driving on one engine?
You want to put some fluid back in that starboard transmission, as the shaft will be turning as the boat moves due to the force on the propeller. You can overheat a transmission like that, although I'm not sure if it would happen at a slower speed like you might be limited to. (side story... my great great uncle was an 'oiler' for his first job on the Great Lakes back in the early 1900's and was on the maiden voyage for the railroad ferry/icebreaker SS Chief Wawatam. The boat had two propellers in the stern and one in the bow and his primary job was to make sure the bow shaft was lubed as it was turning with just the force of the water)
Anyways... back to your issue. You might want to grab an low-cost IR temp gun to do your transmission checks and check the temp more often than 3 hrs. They're pretty cheap and will come in PLENTY handy for all kinds of things. I would definitely keep an eye on that transmission as it's going to have a lot of load and at the lower RPMs will not have as much fluid pressure to keep the clutches locked up as it normally would if the boat was on plane.
- Been thanked: 654 times
- Has thanked: 603 times
The cost of issues on your trip may possibly out strip any tow cost. Sorry that is just how it appears if it were me.
Did you fill the trans with fluid and check.....for sure get a new cooler with your new trans.......good luck man and stay safe.....
- stutting
I think we're going to pull the transmission and a replace where she sits.
My SOG one one motor against the current at mm118 to the first lock would be about 4mph. I planned it to be 10hr runs with checks every hour or so and a cool down half way.
Tow isn't an option down there easily. I have US Boat, no towing service or independent towing. I can get Port Charles to come out I believe. A bit unnerving to have US Boat tell you to call 911 for assistance. I radio US coast guard south of Cape Girardeau. Since I was safely tied to a tree they would not tow me either. Thank the Lord for wonderful people on the Mississippi.
Princeton Iowa
The critical temperatures for the transmissions would be over 200 degrees... say 225 or so. You shouldn't see anything near there though. The "official" Crusader temperature alarm is at 235 degrees, and that means SHUT DOWN NOW!!!
If you were below 190 I would feel comfortable. There are way too many variables to determine the expected temperature... the raw water temperature, the actual load on the gears, the lubricating properties of the actual fluid inside, and restrictions in the line (there is a debris screen in the circuit), and the condition of the trans fluid cooler. If it's still stock then the raw water flows first to the trans temp cooler, then the engine oil cooler then to the engine, so the trans cooler gets the coldest raw water.
Did you contact Carver directly? They would have MUCH better records than any of their dealers, and if you have your hull number they can provide a lot of info on how the boat was originally equipped. That said, there's some recent changes in their customer support due to the sale, so you might want to try there before it's too late.
- stutting
Princeton Iowa
Personally, I'm not a big fan of doing the electric fuel pump conversion on those engines, but in a pinch you have to do what you have to do. Did you also install a oil pressure cut-off switch for the pump? (safety issue). The mechanical pumps are very reliable and the Sierra ones are not very expensive but the mechanical pumps have much better suction capability than the electric ones.
