Bonding system cleanup and repair
- BarryK
- Vessel Info: 1990 Santego 3467
Twin 454 Crusaders - Location: Oxnard, CA
- Has thanked: 12 times
- Been thanked: 6 times
I just cleaned the bilge and it is time to address the bonding system on this 31 year old salt water boat.
All of the bonding connections and bus bars are green with corrosion. I will check the ohms with a meter. What is the best way to clean off the corrosion? Will I need to cut off the ring terminals and put on new ones? Should I replace the screws and washers that connect the ring terminals to the bus bars? Are these brass or some other material?
The system is working I guess since the large zinc on the back of the boat is being consumed normally.
Thanks,
Barry
Re: Bonding system cleanup and repair
The best way would probably be to scrub with a light acid (maybe something like a strong vinegar or muratic acid) and a stiff bristle bush, rinse with clean water and dry. Then remove the connector and scrub lightly with a green Scotchbrite pad. Replace the connector if it's badly corroded and you can cut the wire back enough to get to clean metal. Then put the whole thing together and coat with something like T-9 or another corrosion-blocker.
- Has thanked: 603 times
- BarryK
As for 'letting it soak'... I wouldn't leave it there too long. I think it's better to periodically brush it around so you get 'fresh' material on the corrosion. Maybe work a few different locations at a time and circulate between them every few minutes until those are done and rinsed off, then move onto the next set.
When working with non-ferrous metals, avoid using steel wool or a steel wire brush. Better alternatives are a stainless steel or bronze/brass brush, or bronze or scotchbrite pads as abrasives.
- BarryK
Barry
