2001 46 foot Carver aft cabin
Re: 2001 46 foot Carver aft cabin
Postby g36 » June 8th, 2021, 3:41 pm
Welcome
1966billprice
Vessel Info: 46 2001 Carver aft cabin
Postby 1966billprice » June 16th, 2021, 8:17 pm
I ran across a Carver 466 and measured from the flybridge hardtop to the waterline and its 16 feet 4 inches.
I have a couple of 17 ft bridges to go under on my run to Lake Champlain. So I will have to make sure her gas tanks and water tanks are full.
1966billprice
Postby 1966billprice » June 20th, 2021, 3:46 am
Where do I find canvas covers. I have a 46 foot carver motoryacht and I want to replace instrument panel cover on fly bridge and cover for captains chair.
Postby Viper » June 20th, 2021, 8:59 am
I would hire a local canvas shop to come in, make patterns for what you need, and fabricate new ones from scratch. It's the only way to ensure you get a proper fit.
Postby g36 » June 20th, 2021, 9:00 am
Probably won't find any already made that would fit tight. It's easy enough as a diy project to by sunbrella fabric and measure and sew depending on you coverage goal or you'll have a canvas guy come out and he will measure and custom make one.
plittle2005
Vessel Info: 1992 Carver 350 Aft Cabin
Has thanked: 16 times
Been thanked: 37 times
Postby plittle2005 » June 24th, 2021, 1:55 pm
You could measure from a straight-edge across the highest point on the hardtop (2x4, leveled) down to about 2-3 inches below the bottom paint line, or to the scum line, if present.
Do not use the Brochure figure, it is just a guide. My 350 AC draft, for instance, brochure: 31". As measured, 42"!
Measure carefully!
Phil Little
Users browsing this forum: No registered users and 47 guests
