Shower sump
jsurfwhite
Vessel Info: 2000 Carver 356 Aft Deck
Has thanked: 12 times
Been thanked: 4 times
Shower sump
Postby jsurfwhite » July 7th, 2021, 7:02 pm
My forward shower sump has failed on my 2000 356 Aft Cabin. What are recommendations on replacement? I see an Atwood sump box on Amazon that may work. Thanks
Re: Shower sump
Postby g36 » July 7th, 2021, 7:37 pm
Whats meant by failed? Float switch ? or you could take the pump out and check the bottom of it for hair etc that can get wrapped around the shaft. You could just replace the switch or pump that's in the sump now . Good chance it's a small rule pump.
jsurfwhite
Re: Shower sump
Postby jsurfwhite » July 8th, 2021, 6:37 am
Pump is not coming on. Could be pump or switch. I have not investigated failure mode yet. One of my boating associates recommended a full sump replacement.
Re: Shower sump
Postby g36 » July 8th, 2021, 7:34 am
I would then check for sump breaker tripped. If it is Then pull pump and check for hair at bottom of pump this can cause pump breaker to trip. And test float if not pump.. my sump breakers are under step coming in from sun deck not sure if yours on 356 is same.. You can replace the whole box but save some money and replace only whats needed. Imo.
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 413 times
Re: Shower sump
Postby Cooler » July 8th, 2021, 8:55 am
I would think it is just the float switch. You can test by bypassing the switch. If it is the float switch, make sure you replace with a low profile type like the flat Attwood. Needs to stay under the screen and still get to on position. $40 instead of $200, and much easier to replace. 8-) er
Cooler By The Lake
Re: Shower sump
Postby g36 » July 8th, 2021, 10:58 am
I only posted about hair on the pump throwing breaker because I have had this happen to me and I sure never thought about it being the problem. Either thing pump or float should be a easy fix
Rob Lynch
Vessel Info: 1996 carver 440 my / 1125 hrs / twin Cummins 6ct8 turbo
Re: Shower sump
Postby Rob Lynch » July 8th, 2021, 11:17 am
Just had this issue last week on our 440. Older floats relied on a mercury ball which is likely the issue. Cut the electrical feed wires and touch together. This should activate the pump confirming your float requires replacement. Inexpensive (50) and no more than 30 mins to complete
