Head - What Brand Did Carver Use?
CarolynJean
Vessel Info: Carver Allegra 2587
Postby CarolynJean » June 14th, 2021, 10:56 pm
IHi All. I’m new. I have a lovely 1990 Carver Allegra 2587. Smaller than most of you but I love her. It is in pristine condition but I noticed there is a leak from the base of the head and i want to correct it. The manual refers to the head only generally. Does anyone know how to find any detailed info about the brand, or a diagram of what it underneath/how it connects to the floor? Obviously screws, but I wonder if there is special plate that may be cracked, something like the wax ring household toilets have. Thanks for pointing me in a direction !
Not sure why I am Scurvy Dog lol. The boat is Happy Place.
vineyardgray
Has thanked: 128 times
Been thanked: 33 times
Re: Head - What Brand Did Carver Use?
Postby vineyardgray » June 14th, 2021, 11:05 pm
Welcome.
If you post a picture I'm sure someone can help - Carver may have used many different heads. Dometic and Raritan are two common brands.
M/V Gilded Splinter
1988 Carver
3867 Santego
PCYC
Postby km1125 » June 15th, 2021, 9:11 am
There is not a wax ring, but typically "O" ring seals in various places.
If you can post some pictures of the head, likely someone can identify it.
Liechtenstein
chpsk8
Has thanked: 27 times
Been thanked: 76 times
Postby chpsk8 » June 15th, 2021, 10:01 am
I'd venture to guess it's a Raritan "something". They have a list and pictures of heads on their site that you can use to figure out what you have.
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 413 times
Postby Cooler » June 15th, 2021, 10:08 am
If it is electric, it is most likely a Raritan Crown. That model was probably the most popular, frequently used. 8-) er
Cooler By The Lake
Postby Viper » June 16th, 2021, 6:56 am
I agree with Cooler, if it's original, a lot of Crowns were used around that vintage. Does yours look like it sits on a box or have a box enclosure like the picture in this link?..... https://www.raritaneng.com/en_US/products/crown-head
CarolynJean
Postby CarolynJean » July 16th, 2021, 12:43 am
Thanks so much for the reply, everyone! I have looked a bit into Raritan/Crown and with your advice, I will dig deeper. It is manual/hand pump and totally clean. Except I can’t use it. : (Here is a pic. I appreciate your input if the pic gives you more info.
Postby Viper » July 16th, 2021, 6:59 am
That looks like an older Raritan PHII. You can still get rebuild kits for those. They changed the design of a couple of components in 1992 so be sure you get the right kit for your vintage (pre or post 1992) if repairing is the way you decide to proceed. If you're sticking with a manual toilet, rebuild your current one, they're one of the best manual toilets out there IMO. The only thing that would leak at the base is the base seals of the bowl or pump, unless the base itself is cracked, there is no seal on the floor. Check the discharge fitting on the back of the pump too as that might be leaking as well.
https://www.raritaneng.com/fileslibrary/fb/manuals/phII/phii-exploded-parts-view-fb/mobile/index.html
https://www.raritaneng.com/fileslibrary/fb/manuals/phII/phii-owners-manual-fb/mobile/index.html#p=1
Cooler
Postby Cooler » July 16th, 2021, 10:03 am
I had one of those on a previous boat. 2 places established a leak. The output hose, - solution was to double clamp it. second place was the plastic base. It did crack at some point. You can buy just the base and replace it. Smelly but easy job. Remove the base and the hand pump assy. Inspect the base for a crack, and replace if needed. Wear gloves. There are several places it could be leaking, then just dripping down to base. Good luck. 8-) er
Cooler By The Lake
Postby km1125 » July 16th, 2021, 10:51 am
I had two of those on my boat. They were the electrified ones, but identical except they bolt a motor on that does the work instead of you having to use the handle. I agree with the earlier posts... easy to rebuild and good units.
Users browsing this forum: Google Adsense [Bot] and 20 guests
