Generator Trouble Shooting help
- RussL
- Vessel Info: 2000 396 Motor Yacht
- Has thanked: 18 times
- Been thanked: 11 times
- Has thanked: 602 times
Re: Generator Trouble Shooting help
You tested it with a good battery tester? Connections are clean and tight?RussL wrote:Source of the post ..... Battery is charged....
Check to see if there is a start switch on the generator and try starting it from there. Usually the switch also has an "Auto" position, if it's not left in that position it won't allow you to start it remotely from your electrical panel.
- Rocketman
- Vessel Info: 2009 44 Sojourn w/ Volvo Diesel D6-500 engines and IPS drive system.
- Been thanked: 24 times
