Underwater lights
- Lyndon670
- Has thanked: 124 times
- Been thanked: 140 times
Underwater lights
Last winter I installed 4 Ocean LEDS. I bought the highest lumen rating they had at 1400. They are all aluminum castings with 5 bulbs inside. The great thing about these lights is that they are quality made in USA. These are by far the brightest lights I have seen in any boat. Anchored in the clear water at Beckwith Island, Georgian Bay, I throw light an easy 100ft behind my boat.
Super easy install, an hour for mounting and running the wires and about 2 hours to do the actual electrical side. But I complicated this part by adding a new power bus in my master cabin bilge for the power supply AND added a 12v motorcycle alarm remote control - which gives me the ability to turn on/off the lights and dim/brighten them from 250ft away.
This winter I am adding 2 more, as Ocean LED just came out with higher output ones at 2800 lumen each.
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
- Lyndon670
Re: Underwater lights
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
- Lyndon670
I used plastic ones on my Silverton but was not happy with their performance.
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
There are many variables dictating how long before aluminum shows signs of giving up metal. Everything from water conditions, marina conditions, even your neighbor's boat will influence that. Some boaters have caught on at the first signs of problems and started painting the casings when anti-fouling in an effort to delay the process. Yours may last a long time, let's hope they do, but it's something folks should be aware of when considering a purchase IMO.
- Lyndon670
My statement was that I am very far away from my SHAFTS which I am.
When I spoke of the performance of the plastic ones, I wasn't speaking of their lumen output. The heat generated by the LEDs caused the plastic lens to go somewhat hazy.
You are correct, if a purchaser properly does his research as I did, you can come up with data that can help you make an informed decision. My research resulted in the satisfaction that mathematically these lights (casing) will probably outlive the life of the boat. That is true for my boat as equipped, but may not be true for others.
Quite frankly, boating in Canada with our limited season - even the anodes typically live a long, long time. I just replaced the anodes on the 506 last March - and they were original. I only replaced them because I am very particular, and they still had more than 50% life in them.
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Don't even get me started on anodes, they are meant for one purpose only, to give themselves up (sacrifice) instead of the more expensive hardware. If they are lasting for years, it's likely they are not doing their job or they wouldn't last that long. There are a few reasons for longevity but the most common is simply using the wrong ones.
Not going to get into a pissing match so I'll end it by saying this; Marine engineers also designed the aluminum ones I've replaced. You are right, calculations and mathematics are great and serve as a baseline but I'm talking about real world conditions here. My world is also only about 6-7 months longs.
So we'll just agree to disagree!
Anyway, I love the picture with them lit up
