325 Aft Cabin - Pokey Speeds
- Has thanked: 603 times
Re: 325 Aft Cabin - Pokey Speeds
- Thekaj
- Vessel Info: 1995 325 Aft Cabin
- Been thanked: 4 times
Thekaj wrote:Ah, good suggestion. But unfortunately, the report only notes that they're 4 blades.
Do you have carbs on these engines or throttle body injection ?.....in any case check, with the ENGINES OFF.....see that you are getting wide open throttle when the helm controls are pushed to the stops. The throttle plates should be full wide open vertical. Only check with engine off.... Never rev boat engines excessively at the dock.
And while you have the flame arresters off give them a good clean......
Do you have trim tabs and are you SURE they're fully retracted?
- Thekaj
We do have trim tabs, and I can confirm that they work properly. It actually took me a while to recognize how the indicator display actually reports the position of the tabs. Turns out they're a lot slower to move than my prior boat.
- ColRon
- Has thanked: 77 times
- Been thanked: 157 times
“Escape Plan”
Murray, KY
- drewp
- Vessel Info: 1996 325 Aft Cabin
- Has thanked: 12 times
After re-reading the thread, I wanted to comment on this:
Thekaj wrote:Source of the post .... By coincidence, I took photos where you can see the props when it got hauled out last Summer, so I've been trying to compare them to props on other 325's. It kind of looks like they might be smaller than the other ones I've seen, but that might just be confirmation bias. Plus, it's not like I can tell the angles via photos from 15 feet away. ...
If your props look SMALLER than the other ones you've seen, then that's even MORE of an issue if you're not hitting spec RPMs. Smaller props (either pitch or diameter) would allow your engines to spin FASTER at any given hull speed.
Hope the OP comes back and updates as to what he found!!
- Been thanked: 654 times
- Mikwallace
- Vessel Info: 1998 Carver 405 AC 7.4 Horizon engines
- Has thanked: 117 times
- Been thanked: 23 times
g36 wrote:Source of the post I would also suggest this for others. during pre purchase survey during sea trial and run up to wot to verify boat will do it and then if not why and then you have a known mark for future reference.
I’m looking at doing a survey on Aug 8, 2022 on a ‘98 405 A/C. Are the props marked with pitch size? I’m sure my Surveyor will make note , but would like to know for my reference.
1979 Caravelle 18’
