Charger not charging batteries when on Generator
- denders
- Vessel Info: 1985 Carver 3607 Aft Cabin
- Has thanked: 2 times
- Been thanked: 24 times
Thanks in advance
- Been thanked: 654 times
Re: Charger not charging batteries when on Generator
- denders
Normally you will have a battery/engine, a house battery and a generator battery so 4 in total. Problem is someone may have reconfigured as many do to have a larger house bank. Gonna need to get in there with a volt meter and study the wiring to figure yours out.
- Has thanked: 602 times
It may be time like you say to move on from that charger. Also a quick check of the generator output may not be a bad idea here......you want to see around 59 to 61 Hertz at around 120 volts.
- denders
denders wrote:Source of the post I didn't think that would be an issue since everything else including the A/C is working fine on generator power.
Actually, all the other equipment will probably operate if the cycles are off, but whether they work up to par is another matter.....old style chargers not so much.....worth a check to put that to bed......good luck an your hunt..
I would think with a NEWER charger that the voltage and frequency of the source (generator) would be more of an issue. The older ferro-resonant chargers would take just about anything and still run fine.
What kind of transfer switch do you have to switch over from shore to genset power for the 120VAC? Some of the older ones had a manual switch but some had an auto switch. Could be that the charger breaker (is it on a dedicated breaker??) is wired into the transfer switch so that it won't run unless you're on shore power. Take a pic of your VAC power panels and post them... I wonder if they're stock. You'd have to open up the rear compartment to check the wiring for changes from stock though.
- denders
.- tomschauer
You want to disconnect the charge leads to the batteries and see what you have.
