Riviera bilge question
Re: Riviera bilge question
- hcarmich
- Vessel Info: still looking
thanks again
- hcarmich
We are losing water and think that there is a problem with the heat ex changer causing the water loss. If we do not cap off the heat exchanger - and there is a crack etc in it, wouldn't the water escape from it? So, should we cap it off to see if that is where the water is going?
thank you
After that, you COULD cap it off and continue to use the heater, but I wouldn't use it as drinking water because you've then confirmed that there's a 'breach' in the potable water side. (well, it's hot water so you probably wouldn't be drinking it anyways)
- hcarmich
Our boat lists to starboard. Granted, there are a lot of things on the starboard side (fridge, console, cabinets with dishes), I have a 50lb outboard on the aft starboard rails. Any recommendations or thoughts? I suppose I could load up more fuel on the port tank to try and compensate. Thanks!
- Has thanked: 603 times
- Lizzie
- Vessel Info: 1985 Carver Riviera 28 Aft Cabin
New yachters, so lots to learn.
Trenton, Ontario, Canada
- hcarmich
So, finally we isolated the cold water lines from the hot water tank. We actually have a valve in line now to shut off water going to the hot water tank.
The pump and water performance at the tap is as it should be. There is a small accumulator in the system that is faulty (another matter), but we are not losing water and the pressure is being maintained with the taps closed.
So, there must be a crack in the heat exchanger within the hot water tank.
For our next trial, we are going to remove the lines to the heat exchanger, loop them and plug off the in/out ports on the hotwater tank for the engine lines. This way we can determine if we still have hot water using A/C.
Not sure if it is worth replacing the heat exchanger - or just replacing the 18 year old tank.
Thanks everyone
