Hurth coupled to 454 Nercruiser
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
- tonyiiiafl
Re: Hurth coupled to 454 Nercruiser
Maybe it squeals a bit?
The tranny should have Dexron ATF. Suck it out through the dipstick port and refill there. The filter can be cleaned and reused.
Unless it's obvious when a piece of hardware is squealing, a squeal in the engine bay can sometimes be a challenge to narrow down the source as the acoustics in the compartment can play tricks on you. It can be anything from something on the engine such as one of the pumps, alternator, belt, a pulley, or a tensioner. It could also be the packing gland, strut bearing, a misalignment, the fan in the charger if applicable, or something vibrating resulting in a squeal.
Does this happen both in gear and in neutral? Sounds like you're getting a squeal from both port and starboard sides? If so, shut down one engine and try to narrow down the general are of the squeal first to either the front or rear of the engine then go from there. Depending on what it is, a squeal can be generating heat, take an IR gun and point it to different components and compare the reading to the other engine. Shoot the shafts of pulleys and the hardware mentioned above and see if any raise a red flag. There's also the screwdriver trick or mechanic's stethoscope, just be careful. Make sure nothing else is running like the blowers, AC, etc.
