33ss 8.1 crusader engines fluctuating rpms HELP
Re: 33ss 8.1 crusader engines fluctuating rpms HELP
If it is indeed crud in the tank, getting to them won't help.
You need to get the fuel polished again.
If the cleaning was done the first time with low tank levels, its possible that when you filled up more crud was cleaned from the sides of the tank.
It is also possible the new fuel you got is bad.
It happens a lot.
If you don't have the Oberg filter, you likely have an in-line filter assembly mounted directly to the low pressure fuel pump by the Racor filter assembly. This assembly has a filter element inside and is rarely serviced.
If you have a fuel control cell which is a long canister with hoses and wiring usually at the front of the engine, there is a filter element in it that again is usually overlooked.
Hope you solve the issue. Keep us posted.
- Has thanked: 603 times
Two big block engines running will change the air in the engine compartment quite efficiently. You will really have to go thru that compartment and cross things off the list one at a time going thru the fuel feed system first one component at a time.
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
buster53 wrote:Source of the post Replacement filter is R11S
Buster, are you sure that is enough fuel flow for higher throttle settings.....seems a bit low unless I am missing something.
- buster53
bud37 wrote:buster53 wrote:Source of the post Replacement filter is R11S
It’s not unusual to have a 10 micron filter as primary and a 2 micron as secondary. That’s what was on the engine when I bought the boat. I have no problems getting up to WOT and usually cruise at 3100.
Sorry for the hi jack.
- buster53
bud37 wrote:FYI...the R11-S is 2 micron max flow 15 gph diesel filter element...R11-T is the 10 micron 35 gph element for gas in the same filter housing....that is why I was puzzled. Restricted fuel flow equals less available HP.
Not saying you are wrong…the S is what was mounted on my motors when I bought the boat. I bought new ones to replace them and my mechanic didn’t suggest otherwise.
Of course, I rarely run the boat at a speed that would exceed 15 gph.
