Replacing Air Conditioning Water Pump
- FreedomWorks
- Vessel Info: 2003 Carver 366
Brand new to the forum and a new (1 year) boat owner.
I’m trying to replace the air conditioning water pump on my 2003 Carver 366. I can’t figure out how to remove the coupling between the pump intake and the sea water strainer, or if I need to remove it at all. Could I simply remove the nuts that attach the pump to the boat structure and rotate the pump to unscrew it from the coupling or is there a way to undo the coupling? I tried undoing the coupling by hand and it seems pretty difficult; plus I’m afraid to apply too much force.
I’ll attach a pic of the pump and a close-up of the coupling.
Thanks much!
FreedomWorks
2003 Carver 366
[image][image][image][/image][/image][/image]
Re: Replacing Air Conditioning Water Pump
If you have a strap wrench that might be the easiest to get ahold of that big "nut" in the middle. You can also use some channel locks or even a pipe wrench, but those will mar it up
Here's a link to one in a store... you could go there and see how they come apart if that helps
https://www.lowes.com/pd/Charlotte-Pipe ... ng/3695994
Here's a better angle on a similar one where you can see the threads that the "big nut" comes apart from
- FreedomWorks
If I may ask another question; how about the joint on the output (pictured below)? Any ideas on getting that one apart?
Thanks Again,
FreedomWorks
2003 Carver 366
- FreedomWorks
- Has thanked: 474 times
- FreedomWorks
The other difficulty has been removing the pump from the board it’s mounted to. The locknuts won’t loosen because the bolt’s screw heads rotate when I turn the locknuts. I think I’ll have to remove the seawater straining housing, then the mounting board and then I’ll be able to get to the bolt screw heads.
- FreedomWorks
- FreedomWorks
I feel like I’ve got a couple of choices. I could cut the hose but then I’d need to figure out a way to splice it to regain the length I’ll need. I’ve never done a splice and have no idea if it can be done or is a good plan.
The other option is to cut the plastic pump output (about where I’m pointing in the attached picture). Once it’s cut I think I’ll have better leverage to remove the hose by doing 360 degree twists while pulling.
Any thoughts on these options (or other, better choices I haven’t considered) would be much appreciated.
Thanks Gents,
FreedomWorks
2003 Carver 366
