Best DIY way to drain gas tank?
- darylann
- Vessel Info: 1992 Carver 33 Aft Cabin... My first boat!
Dreamed and schemed for 7 years, and finally made it happen in 2017! - Location: Peoria, IL
- Has thanked: 78 times
Some say just add a bottle of Heet and about 15 gallons of gas and I’ll be good to go. Others say NO, drain that tank to get all the water out before putting good gas in! I wish the Heet would be a quick, cheap and easy fix, but I’m thinking draining it would probably be best.
Opinions? Suggestions?
Peoria, IL (for now)
My first boat!- tomschauer
Re: Best DIY way to drain gas tank?
- Has thanked: 603 times
- Been thanked: 654 times
The boat I referred to the, tank was never drained, the boat continued with the second owner for close to 10 years with no water/gas related issues. Just saying it could be a very quick fix.
g36 wrote:Source of the post Use a small electric fuel pump like a Mr. Gasket 12S Micro Electric Fuel Pump to drain into portable jugs. Something like $30 on Amazon. could remove the gas tank sender and drop a tube to get most out or hook it up to fuel line which will leave some. I've set up a remote switch to control mine, you must be concerned with sparks but this pump will do great.
^^^THIS.
I was wondering if my tanks had collected any water, so one year I ran the tanks down below half on each then I used a 5' copper pipe connected to a similar pump and was able to lower that pipe down into the tanks from the fill port (it was a straight shot right down into the tank). Ran that through a water-separating filter and then pumped it into the other tank, until I drained it completely empty. Then, I reversed the process pumping all the fuel back, completely emptying the other tank. I ended up finding absolutely no water so I was happy.
If you don't have a straight shot in from your fill port, you might have to pull the fuel level sender and lower a hose that way.
Do not do the HEET and more gas thing
This is the rig I built (was only about $80 IIRC)
- darylann
Midnightsun wrote:Do you not have water separating fuel filters? these should fill up before you have running issues. Had this happen to me many years ago when coming back on fumes in very agitated waters. Lesson learned and to this day carry spare filters on board. With only 15 gallons remaining (maybe only a few) and the boat movement, even small quantities of water will get picked up and gradually fill the filter leading to poorly running to no go.
Great info… Thanks for sharing! I will check this out for sure! Every time something goes wrong on my boat, it’s a part of a system I haven’t worked on yet and a total learning process. I’d like to do as much work as I can myself, so I can learn every inch of my boat and maintain it myself when possible. Thanks again!
My first boat!- Midnightsun
If it starts sputtering next season this would indicate enough water in the tanks so you may need to empty them however my gut feeling is it just sucked up enough water over X amount of time running on nearly empty tanks and since you never changed the filters, this is what happens.
- Dewmyster
- Vessel Info: 1998 370 Voyager
- Been thanked: 12 times
