Install New Jabsco Head
nootcheez
Vessel Info: 1988 Carver 4207 Re-engined with Yanmar Diesels in 2013 (was gas 454). Recently purchased.
Has thanked: 4 times
Been thanked: 2 times
Postby nootcheez » October 4th, 2021, 3:02 pm
Installing a new Jabsco head. Current head has a (I think) 60 amp breaker and correspondingly large capacity wire (battery cable size). New unit calls for a 25 amp breaker and 8 gauge wire. Need to find a 25 amp breaker switch to match current switches in panel.
Thanks greatly for any help , advice or direction!
Kevin
1988 Carver 4207
Kevin
1988 Carver 4207
nootcheez
Re: Install New Jabsco Head
Postby nootcheez » October 4th, 2021, 3:40 pm
Found them at Great Lakes Skipper. Current breaker has wire direct from battery. I am planning on changing power source to main switch on panel. Any info on amp capacity of mains?
Again, thank you!
Kevin
1988 Carver 4207
