Location of hydraulic steering pump on 1986 Carver 42 Aft Cabin
- curran_286@msn.com
- Vessel Info: 1986 Carver 42 Aft cabin motoryacht
- Has thanked: 4 times
I'm slowly learning where everything is located on my Carver. My steering is operational in the lower helm, but not working in the upper helm. It was suggested that the system may not need fluid, but may need to be pressurized to 15-20 PSI. Does anyone know where the hydraulic steering pump is located?
Much appreciated,
John
Re: Location of hydraulic steering pump on 1986 Carver 42 Aft Cabin
- denders
- Vessel Info: 1985 Carver 3607 Aft Cabin
- Has thanked: 2 times
- Been thanked: 24 times
- Been thanked: 490 times
You may have access through the port side "night table" next to the bed. There is a removable panel in the lower section.
If not, you may have to remove the mattress, then the cover, then another cover under that storage compartment.
If that's where it is, I suggest you climb into the storage space under the bed before heading to the bilge with your arms. I did- not do this and went in from the bed platform. I got in alright, and then slipped in a bit farther, and could not get out. My wife was visiting a neighbor's boat. And there I am beating in the hull and screaming "Help!" Finally she hears it, comes down to the aft room, sees my legs sticking out of the hole in the bed platform, and of course, begins to laugh. Avoid that! But have somebody nearby in case you can't get out.
- Has thanked: 603 times
waybomb wrote:Source of the post sees my legs sticking out of the hole in the bed platform, and of course, begins to laugh. Avoid that! But have somebody nearby in case you can't get out.
Did she take any pics of this you can post.........
Users browsing this forum: MrMojoRisin and 23 guests
