Fresh water pump.
Scott892
Vessel Info: 2007 Mariner 360
Crusader 6.0
Been thanked: 2 times
Fresh water pump.
Postby Scott892 » October 30th, 2021, 4:57 pm
My fresh water tank pump filed. It was a Par Max Plus, 4GPM, 12amps, 15 amp fuse. The closest replacement I could find was a Jabsco Par Max, 4GPM, 10 amp, 15 amp fuse. It works but makes a thumping sound and trips the breaker after continued use. Especially when I run the shower?
My dock neighbor suggested that maybe it's too powerful if it's tripping the breaker. But that doesn't seem likely given the specs? Maybe it's just a bad pump?
buster53
Vessel Info: 2001, Carver 356
Has thanked: 10 times
Been thanked: 285 times
Re: Fresh water pump.
Postby buster53 » November 4th, 2021, 1:33 pm
Before you do anything, like replacing the pump, I suggest replacing the breaker first. Breakers do go bad and yours may be headed that way.
buster53
Postby buster53 » November 4th, 2021, 3:02 pm
As to the thumping sound…turn on several faucets at the same time, full blast and see if the thumping goes away. Let us know what happens.
Users browsing this forum: Google [Bot] and 36 guests
