Inverter and transfer switch
tonyiiiafl
Has thanked: 601 times
Been thanked: 193 times
Postby tonyiiiafl » December 26th, 2021, 5:38 pm
Thinking of installing an inverter with a transfer switch. now I have twin 30A shore power, a genset ans solar connected to the house bank, where the inverter will be. I saw the GO Power TS30, which has 2 separate sources of input power. How would this work with the twin 30A cords? Is this an install for a pro?
Re: Inverter and transfer switch
Postby km1125 » December 27th, 2021, 10:53 am
I'm guessing most of one of those 30A inputs is just HVAC stuff. If you're not planning on running that with the inverter (that would take a HUGE battery bank), then just installing the inverter on the other 30A input would be what you'd want. However, you might also have some big loads on that side, like a water heater.
You really have to figure out your plan on what you want the inverter to power and how long your bank will support your needs. That would drive how you integrate it into the panel(s).
tonyiiiafl
Postby tonyiiiafl » December 27th, 2021, 11:34 am
Totally on point. More to think about
Tireless
Volvo Penta D6 370 HP
Has thanked: 183 times
Been thanked: 187 times
Postby Tireless » December 27th, 2021, 3:40 pm
I would only run one side of your panel with the inverter/transfer switch and that would be the house side. Not practical, nor wise to run A/C, Hot water, Ice makers or ovens with the inverter. If you have a generator, use that for the big stuff.
Use the inverter for receptacles for running electronic equipment, lamps etc. Just ensure you get a pure sine unit.
I only use smaller inverters to assist me while I on the hook, like for my CPAP machine. I have no need for inverter wired into the panel. It is strictly a personal choice, for sure
Greg
Return to “Electrical”
