Carver 3207 Engine problem
- throwback2
- Vessel Info: 1987 Carver 28 Voyager,twin small blocks,1991 Shamrock,350 Chevy now.
and a few other water toys - Has thanked: 8 times
- Been thanked: 23 times
Re: Carver 3207 Engine problem
- throwback2
- ataylor233
- Has thanked: 83 times
- Been thanked: 7 times
throwback2 wrote:Source of the post Electronic distributor conversion? Did you bypass the ballast resistor? Most of the conversion kits want full 12 volts to work properly.
I didn't only because the instructions said don't bypass if I have one... I will try to bypass it first
Don't loosen the distributor and change the timing. Find out first why you're not getting a good spark at the plugs. Your low voltage circuit is working and so is the high voltage side from the coil or you wouldn't get a spark at your cap as you described. The problem is likely from and including the distributor components; rotor or cap to and including the wires and plugs, or a voltage issue as I mentioned before.
I take it the tool you used to check spark is hooked up at the end of each plug wire where they would hook up to the plugs? Did you check all plugs to see if any are firing?
Swap the cap and rotor from the working engine to the other and see if the problem follows the parts.
With points, it's VERY EASY to check for a good spark. All you have to do is turn the ignition on, loosen the distributor, and move it back and forth. You'll get spark each time the points open. You do have to set the timing after you do that, but you should be checking the timing anyways on a poorly running engine.
Once it's running FINE, then I'd consider doing the upgrade to an electronic ignition module. That way you're not questioning if it's something in the module or the install (resistor/no_resistor) when trying to get the engine to run properly.
I upgraded both my distributors to Prestolite electronic units, but the engines were running fine before the switch. Much easier not having to mess with the points for years after. However, you still need to check/change the rotor and cap every now and then and also check/maintain that mechanical advance mechanism.
- ataylor233
In many "reverse rotation" engines, they still used the same distributor because the cam and distributor rotated the same regardless of the crankshaft rotation. On a normal rotation they used a chain between the crank and can, so they both rotated the same direction, but on a "reverse rotation" they used gears between the crank and cam which caused the cam (and hence the distributor) to rotate opposite the crank.
Users browsing this forum: Google [Bot] and 36 guests
