2003 Carver 444 draft when full
- Piggy3
- Vessel Info: 2003 Carver 444
- Has thanked: 12 times
- Been thanked: 2 times
Thanks in advance
Re: 2003 Carver 444 draft when full
- RobGunn
- Vessel Info: 1990 Carver 3607 Aft Cabin
"FINALLY" - Location: St. Joe MI
- Been thanked: 23 times
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
These boats are pretty heavy to start with so loading them up has little or no impact on draft. The water and fuel have really no impact on listing either, due to the locations of the tanks and the fact that they are on both sides of the boat. Your two water tanks will balance out, as they are connected and you should have a fuel transfer switch if needed. My fuel burn is so close in both engines, its a none issue.
I measured my draft on the hard and it is 42”.
Greg
I get the comment about the water tank in a two tank system but if you're saying that differing levels in your fuel tanks won't cause listing, I would not agree with that. I agree even fueling up doesn't change the draft that much in your typical leisure application but filling one tank more by tens of gallons will change the even weight distribution and cause a list, how noticeable the list is really depends on a few things including boat design. A list though still doesn't change your draft much if any.Tireless wrote:Source of the post ....The water and fuel have really no impact on listing either, due to the locations of the tanks and the fact that they are on both sides of the boat....
- Tireless
My experience is that fuel in my boat does not cause listing because I keep fuel levels balanced as best I can. I do this through consistent fuel burn in my engines and when I fuel up I make sure that my levels are the same. I agree if one side has more fuel than the other, then you will see that in the balance of the boat. If levels change on either port or starboard, I also have a fuel transfer switch, however, I rarely use this. The only thing that impacts my fuel levels to any degree may be the generator, but not that much.
Greg
- Has thanked: 603 times
RobGunn wrote:Source of the post You could always check it yourself. On a calm day when the boat is "empty" simply mark a line on the side of your boat at the waterline. Then once you are "full" mark that new point. Measure the difference. I doubt you will see much change.
Actually this a a good idea......mark the waterline with something obvious then you can keep track as the season passes and will notice any changes as they will be obvious. If you arrive at the boat and it is showing low in the water, you can start a hunt to see why before trouble starts.......
I don't think you will see much change when the boat is loaded unless you start from bone dry MT.
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
