Carver 33/35/36ss head fill solenoid/valve??
danclev
Vessel Info: 2007 Carver 35 SS
Has thanked: 17 times
Been thanked: 3 times
Postby danclev » January 1st, 2022, 12:22 pm
Hey guys,
The head kept filling after flush, now won't stop filling. Checked switch, seems to be ok. Had to unhook the supply hose and plug it while I troubleshoot.
Has anyone had this issue or do you know/suspect the culprit? I can't find the solenoid/valve that controls the flow either.
Thanks!!
Dan
buster53
Vessel Info: 2001, Carver 356
Has thanked: 10 times
Been thanked: 285 times
Re: Carver 33/35/36ss head fill solenoid/valve??
Postby buster53 » January 1st, 2022, 12:37 pm
What brand/style of head? Fresh or sea water flush?
danclev
Postby danclev » February 12th, 2022, 8:51 am
It is a freshwater flush.
Postby bud37 » February 12th, 2022, 9:13 am
You never said what brand the toilet is.....anyway there is a solenoid controlled by the flush switch.....on some brands/installs the valve is located in the back of the toilet in the fresh water feed line....you will have to see behind, try a mirror and light.
Look on line for a parts schematic/manual for the brand toilet you have.....good luck man.
JohnS
Vessel Info: 2003 350 Mariner
Has thanked: 39 times
Been thanked: 16 times
Postby JohnS » February 24th, 2022, 9:00 am
danclev
Postby danclev » August 28th, 2022, 4:09 pm
A quick update : the solenoid valve is located BEHIND THE REFRIGERATOR on the Carver 33/35/36 SS of all places. Took two people to slide it out and tip it forward enough to reach the valve. Sure enough there was a flake of plastic keeping the solenoid open. Cleared it out and good to go now. Here is a video of the instruction on how to open the valve and clean it out. Took 5 min once I got to it.
