battery shut of switch panel panel
- henry
- Vessel Info: 1987 carver mariner 32 ft
- uchu
- Vessel Info: 1988 Carver Santego 2767 - Twin Mercruisers 4.3LX with Alpha-One drives
- Has thanked: 86 times
- Been thanked: 15 times
Re: battery shut of switch panel panel
Does the pic below look like your panel? Is it the "Main" breaker on the left that's not resetting? (if so) Did you shut off ALL the other breakers on that panel before turning on the main? If that's the one that is tripping, then yes you wouldn't have any DC power to anything except the auto float switch for the bilge pump and maybe the voltmeter(s). Those usually go direct to the battery switch and bypass the main breaker. They are a common breaker, usually made by Carling but a replacement is probably available from Blue Seas too.
- Has thanked: 603 times
henry wrote:Source of the post i have a 1987 carver 3297 mariner there is a 50 amp circuit breaker in the panel i have no 12v power and this breaker will not re set anyone know the part number and would render the 12 volt inop
Is there any resistance when you move the toggle or is just floppy ?
- henry
- uchu
- henry
thaks
- Been thanked: 654 times
- SmokingSailor
- Vessel Info: 1986 Carver Rivera 28 A/C
Cal Jensen 28
PACE 27 - Location: Delaware
I'm having the same issue, except my batteries are fine.
