Anybody else have one of these?
- Tbw5959
- Vessel Info: 2004 466 M/V Salt and Light
Volvo TAMD75's & Kohler 20kW generator - Location: New Bern, NC
- Has thanked: 39 times
- Been thanked: 4 times
So, on this new-to-us 2004 466, 'discovered' this Newmar box mounted on the forward engine room bulkhead, switched 'off'.
Previous owner says he has no idea what it is! I'm wondering if any other Carver owners might have one onboard & can enlighten me.
It says it is a DC-to-DC converter, and the labeling seems to indicate it steps up 12v to 24v at 6 amps, doesn't it?
I thought it might be somehow related to charging the 24V thruster battery bank from an engine alternator - but can find no wiring connections to support that theory.
(And, I also learned in the process btw - the thruster battery bank does not get charged when engines are running! Only when generator is running or shore power connected, and the thruster battery charger is powered on [:-( )
The two 2-conducter cables that connect to this Newmar box run off into wire bundles and I haven't been able thus far to completely trace them out, except to see that one runs forward & one runs aft.... No DC voltage registers on the box terminals with engines not running.
So while this is an ongoing search, thought I'd ask to see if others recognize this and possibly have one in use that you could describe. Any thoughts would be greatly appreciated!
Thank You....
- uchu
- Vessel Info: 1988 Carver Santego 2767 - Twin Mercruisers 4.3LX with Alpha-One drives
- Has thanked: 86 times
- Been thanked: 15 times
Re: Anybody else have one of these?
Maybe as a voltage stabiliser, to reduce interference with communication devices?
- Has thanked: 603 times
Tbw5959 wrote:Source of the post I thought it might be somehow related to charging the 24V thruster battery bank from an engine alternator - but can find no wiring connections to support that theory.
That is a reasonable conclusion.....if your thrusters are the only 24volt hardware on board. Like a lot of things, there is no free ride maybe it worked at some point but not that well and was abandoned or they just did not notice the failure then sold the boat.....keep following wiring and it should explain itself.
- Tbw5959
The nav equipment, including a Raymarine radar, is original equipment on the boat and all operates normally.
Now I'm starting to wonder if maybe this Newmar box is related to or was used by the satellite phone/tv system the original owner had installed, way back (unfortunately the owner is long gone now, and no subsequent owner used that equipment).
If there IS voltage there when the engine(s) are running, but NOT when the genset or shore is available, then that would (obviously) mean that device is sourced from the engine electrical (are both your diesels 12V motors?). That would suggest they were using that to charge a 24V system (the thruster) while the engines were running.
When the DC-to-DC converter is running, what is the actual output voltage? If you measured exactly 24VDC (+/- .5 or so), then it was likely for running some type of equipment. If it was more like 25.2 to 28VDC then it was used to charge/recharge a 24V battery system.
- Tbw5959
I also pulled out the 2 fuses in the Newmar box & checked them, they were fine. And noted the 'On' indicator light on the box doesn't light up, with engines on nor off....
...I also pulled out the 2 fuses in the Newmar box & checked them, they were fine. And noted the 'On' indicator light on the box doesn't light up, with engines on nor off....
Whereever that feed comes from, the wire should be protected with a breaker or a fuse.
One thing that you could do -as a test- is remove the "input" DC wires from the box (and tape them so they don't short anywhere) and run some temp wires from any 12VDC source (could be existing batteries on the boat, or even a portable "jump start" box if you have one of those) directly to the Newmar box to see if the light comes on. If it does, then again check the output voltage and see what you have. If you have >25.2 then recheck the bow thruster batteries to see if that is charging them.
Tbw5959 wrote:Source of the post I also pulled out the 2 fuses in the Newmar box & checked them, they were fine. And noted the 'On' indicator light on the box doesn't light up, with engines on nor off....
It may as simple as the box is just no good, internal fault.
