Welcome to CarverYachtOwners.com!
Been thanked: 470 times
Re: Welcome to CarverYachtOwners.com!
Postby RGrew176 » April 14th, 2022, 2:24 am
Welcome Aboard. Good luck.
thunderbay2tracker
Vessel Info: 1982 carver 3007 aft
Postby thunderbay2tracker » April 16th, 2022, 6:10 pm
thank you for letting me join Im looking forward to enjoy our new to us 1982 carver 3007 in the Great Lakes :captain:
Been thanked: 491 times
Postby waybomb » April 17th, 2022, 8:46 pm
Welcome aboard!
ColRon
“Escape Plan”
Has thanked: 77 times
Been thanked: 157 times
Postby ColRon » April 17th, 2022, 10:43 pm
Welcome Aboard!
Ron
“Escape Plan”
Murray, KY
:usa:
Loopchemist
Vessel Info: 1986 Carver 32 Aft Cabin
Crusader 270 x2
Postby Loopchemist » May 3rd, 2022, 7:30 pm
Hello All
Very new to Power Cruisers. Was a sailor for many years
Now I moved away from the pacific seemed more appropriate to have a motor cruiser.
Just purchased an older 1986 32aft cabin.
Looking for any tips or tricks particularly in engine/boat control. 2 engines is completely new to me. After all I only ever started my sailboat engine to get out the slip and used about 10 gallons a season !!!
Postby waybomb » May 4th, 2022, 12:32 pm
Welcome aboard. Two engines make things easy. When in the harbor, do not use your rudder, use the transmissions for turning, docking, etc.
Once you get that worked out, read up on how the crab a boat. And practice.
Out on the water, of course use the rudder. But also keep the engines synched at the same rpm. If your boat doesn't have an engine synchronizer gage, you should install one.
Postby km1125 » May 4th, 2022, 12:49 pm
thunderbay2tracker wrote:thank you for letting me join Im looking forward to enjoy our new to us 1982 carver 3007 in the Great Lakes :captain:
Welcome aboard!! There are several current (and a few former) owners of 3007's on here. That's a nice boat! Post up some pictures when you get a chance!
Loopchemist wrote:Source of the post Hello All
Welcome aboard!! The 32aft's are pretty nice boats too! Posts up some pics!!
One thing I tell "new to twins" folks is to imagine using the shift levers as if you're standing behind someone and have your hands on their shoulders. If you want them to move or turn, you have to push or pull their shoulders. Think of how they react when you do this and you have a good impression of how your boat would react when using the shifters. Just make sure your wheel is centered when you first start out. After you get the hang of it like that, you can also start using the wheel and rudders and throttles for more advanced handling. Of course all this applies just to the low speed maneuvering. As Waybomb says, when cruising just make sure the engines are synced and just use the wheel for steering.
Loopchemist
Crusader 270 x2
Postby Loopchemist » May 4th, 2022, 6:24 pm
Thank you for the advice so far. Someone else told me to look at the levers for the transmission. They are curved toward each other which also reflects which way the boat will go in forward or reverse. I found that tip useful.
I will send pics soon
ColRon
“Escape Plan”
Postby ColRon » May 11th, 2022, 10:39 am
Loopchemist, welcome aboard! Don’t let twins intimidate you. One I got used to twins, I vowed I’d never have a single again. Twins are so much more
Maneuverable than a single, unless…the single has thrusters.
Ron
“Escape Plan”
Murray, KY
:usa:
Jeff456
Vessel Info: 1998 carver voyager 53
Postby Jeff456 » May 16th, 2022, 2:18 pm
Hello I have a 1998 carver voyager 53 I trying source new wiper arms can anyone help thanks
