low voltage reading
Crowbar
Vessel Info: 1987 Carver Voyager- twin 230 hp gas
low voltage reading
Postby Crowbar » April 20th, 2022, 12:33 pm
1987 voyager twin 230 gas. STB engine only running, voltage shows 10 V. Port engine only running, voltage shows14 + V. Together running, voltage shows 10V. Is it a grounding issue, or is my std. alternator dying?
Re: low voltage reading
Postby bud37 » April 20th, 2022, 7:28 pm
Where are you seeing the 10 volts.....that is very low......check your batteries with a multimeter then take readings at the batteries with the engines on.....don't rely on a dash gage.
Postby km1125 » April 20th, 2022, 7:32 pm
Does sound like there's a problem on the stbd side, but could be a connection or fuse rather than the alternator.
Confused on the "together running voltage shows 10V". Where are you measuring voltage? Do you have separate voltage gauges for each engine? How many batteries, and how are they configured?
Crowbar
Postby Crowbar » April 24th, 2022, 2:51 pm
Well! turns out the wiring harness going to the engine wasn't making good contact. It took alot of troubleshooting, but, wiggling the connection solved the problem. thanks for the input.
Postby Midnightsun » April 24th, 2022, 5:39 pm
Thanks for posting the solution, comes in very handy for others who may have a similar issue. :down:
Users browsing this forum: No registered users and 9 guests
