2004 420 Mariner owners manual
- Advocate
- Vessel Info: Carver 420 Mariner.
2004
Twin Volvo TAMD 63P diesel - Location: Massachusetts
Thank you
Re: 2004 420 Mariner owners manual
- Advocate
2004
- Has thanked: 603 times
- claytonandresen
- Vessel Info: 2004 Carver 42 Mariner
- Has thanked: 1 time
- Advocate
2004
- Phrancus
- Has thanked: 16 times
- Been thanked: 136 times
- Contact:
As you found out and as bud37 pointed out, it will take a bit of puzzling to put together the data you can use.
Besides all that, I must also point out that even the correct manual does not always give you the detail you want. For example; mine does not state explicitly what brands and types of hardware were used. It has a list of optional hardware that may and may not be present in my boat. it does not show what is installed in - for example - wiring for hardware that turns out not to be there.
Luckily, the boats were not put together like CAN-bus vehicles with big wiring looms that contain similar colors in large variations. The only thing I find annoying is that sometimes wiring is tucked behind things that I cannot remove without damaging. So removing panels, seats, looms to figure it out may likely lead to difficulty in putting it all back together nice and tight.
Users browsing this forum: No registered users and 7 guests
