Head pump on constantly
- Lmancuso
- Vessel Info: 2007 42 Carver Super Sport
- Been thanked: 654 times
Re: Head pump on constantly
- tgebler
- Vessel Info: 2000 396 AC
- Has thanked: 5 times
- Been thanked: 29 times
- Has thanked: 602 times
Lmancuso wrote:Source of the post We just put our 2007 Carver 42 Super Sport back in the water and the head pump is running (the head tanks are empty). Any suggestions on how to get it to turn off. We turned the breaker off so it won’t burn out.
If it is vacuflush then it is not making the vacuum setpoint for one reason or another...unfortunately there is not one easy answer......after spring commissioning you will have to check the system/pump/vac tank for ice damage, loose connections after the winterizing, the toilet seal etc etc as there could be many different causes......good luck with it....
- jetstream
- Vessel Info: 2003 Carver MY 466
- Been thanked: 2 times
