Wet Carpet
Soswaldrichmond
Vessel Info: 2001 Carver 466
"Brand New Day"
Wet Carpet
Postby Soswaldrichmond » May 19th, 2022, 2:10 pm
On a Carver 466, I recently found damp / wet carpet at the bottom of the steps leading to the aft master stateroom. We did find a plugged condensate drain on an AC unit but that has been fixed and the AC cabinet appears dry at this time. We checked the AC unit under the master stateroom bed but found nothing wet there. We removed the master bath shower seat for access but can't find any moisture in that area either. Anyone have any thoughts?
Re: Wet Carpet
Postby g36 » May 19th, 2022, 3:58 pm
Just a thought, i had the same issue on my 405 when we bought her. If the carpet is wet outside of a wall by the shower make sure all the caulking on the surround is good. We chased our problem for a bit. The caulking looked good from afar but close up showed some issues once recaulked no more problems.
Or any windows nearby the wet carpet?. Maybe a waterline leaking nearby? Let us know when you do find it. Best wishes
wkeith
Vessel Info: 2004 Carver 466 Aft Cabin MY
Has thanked: 8 times
Been thanked: 14 times
Re: Wet Carpet
Postby wkeith » May 20th, 2022, 7:53 am
I've chased wet carpet problem in the master in front of the starboard side closet. Porthole was leaking water in heavy rains and was letting water run down the chest of drawers. The main culprit was the caulking on the seams in the swim platform starboard side.
Tbw5959
Vessel Info: 2004 466 M/V Salt and Light
Volvo TAMD75's & Kohler 20kW generator
Has thanked: 39 times
Been thanked: 4 times
Re: Wet Carpet
Postby Tbw5959 » May 27th, 2022, 4:52 am
Possibly related to the clothes washer, if you have one in the cabinet there by the stairs?...
Users browsing this forum: Google Adsense [Bot] and 22 guests
