Hairline cracks on entire hull - anyone fix?
Jrizzo003
Topic author - Scurvy Dog
- Vessel Info: 2002 466 Carver; TAMD engines
- Been thanked: 3 times
Spoke to Carver and they admitted that they had a product defect back then and stopped using material from that supplier. Never determined why some boats had cracks and others did not. Either way - they say it's on me to fix it.
Any thoughts? Carver recommends a strip down of the gel coat layer and the barrier coat down to the glass layer. Then add an epoxy filler layer, barrier coat, and bottom paint. Estimate is $10k.
Not sure if I do this or pocket the $10k and see what happens. Boat is 12 years old and has no water intrusion.
I posted pictures in case someone else has had this problem.
Any help appreciated.
2002 466 Carver; TAMD's
Whaleneck Marina
Merrick, Long Island NY
- Lyndon670
- Has thanked: 124 times
- Been thanked: 140 times
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
Epoxying the bottom properly is pretty time consuming and hard work. Add to that the cost of material; epoxy is pricey, and it quickly adds up to thousands. At $10K, I would expect the full pull; blasting all the gel off if the cracks go down to the glass, an epoxy wet-out coat with powder additive to increase adhesion, putty the entire hull with West System product only (some will cheap out here), sand sand sand
, a nice thick barrier coat (Interprotect), I like 5 coats rolled on (alternate colours to ensure full coverage) but you can get a thicker coat per sprayed application, and finally anti-fouling paint and I would only use ablative paint, about 4 coats. If the blasting isn't too aggresive, you may be able to get away with no puttying but for that money, one would expect to include puttying unless there are conditions we are not aware of. Other than maintaining the paint, you shouldn't have to worry about this bottom again providing they know what they're doing and they use the proper products.-
Jrizzo003
Their rationale was that in 14 years (boat is 2002) the hull was not compromised - no reason to think it would not continue to hold up. I don't want to cheap out on this - and I know the 4 coats of epoxy paint is not cheap either - but I do not want to over do the fix either.
Any thoughts on this fix appreciated - -
Whaleneck Marina
