Change Gear Oil in IPS 500 Drive Unit
Rocketman
Vessel Info: 2009 44 Sojourn w/ Volvo Diesel D6-500 engines and IPS drive system.
Been thanked: 24 times
Postby Rocketman » June 7th, 2022, 10:20 am
As the subject states, I am getting close to time to change the drive oil.
It was done while the boat was out for hauling and bottom paint the last time so that was easy enough out of the water.
The manual states that you can change in the water with a pump and adapter fitting.
Question is - what adapter fitting and pump do I need to purchase. I can't find anything on the web or in the manual that has a part number or any details.
I hate to pay to pull the boat along with the 30 mile run each way to the lift.
Would like to be able to do it myself as I do all my other maintenance.
Thanks,
Tony
Re: Change Gear Oil in IPS 500 Drive Unit
Postby km1125 » June 7th, 2022, 11:50 am
I helped a friend change the gear oil in his ZEUS drives, but it was off-season so we were able to do it out of the water and use the fittings on the lower unit (POD), the same way you'd do an outboard or outdrive. The big difference is volume though, and the little pump that you'd normally use would be difficult on that much lube. So I made one. Got some kitchen drain pipe and made some parts with a 3D printer and it worked great. (pic below).
However, when perusing the Maintenance manual for the ZEUS, I did also see where that system could be done in the water. There was a port right above the pod and below the transmission that you could remove and connect the adapter there. I am sure I could have used that same pump I made if we had to use this port. The information was in their Operations and Maintenance Manual, which I was able do download free. The actual Service Manual you have to pay for, but if I owned one of these POD systems, I would spring for the $200 and for sure have one.
Here is the pump I made. next to the stock "outboard" pump:
Rocketman
Postby Rocketman » June 7th, 2022, 12:11 pm
It appears that the Volvo IPS uses a special adapter to screw into the top of the drive to draw out the oil when in the water.
That is the adapter that I cannot seem to find anywhere.
Found the adapter.
Volvo part number - 990038
However, I am confused on the amount of gear oil I will need.
The manual states 7.9 Gal / 30 Liters.
When the marina did it while the boat was out of the water in Jan 2021 they charged me for 8 gallons to do both drives.
Did I get lucky and only got charged for 1/2 the gear oil?
Anyone have an idea?
Postby Viper » June 8th, 2022, 9:02 am
Post the serial number and model of the IPS unit.
Rocketman
Postby Rocketman » June 8th, 2022, 9:38 am
IPS-C
Serial Numbers
3194008125
3194008126
Postby Viper » June 8th, 2022, 4:51 pm
They take approximately 14 liters (14.8 US qt) each.
Postby Viper » June 9th, 2022, 6:58 am
I'm not a fan of extracting oil from topsides, you don't get it all, you may miss water which will sit on the bottom of the lower unit which you want to know about early, and you'll likely only get solids that are in suspension and miss those sitting on the bottom which again is something you want to catch early and assess.
Rocketman
Postby Rocketman » June 9th, 2022, 1:54 pm
I agree. If it was easy to pull, I would do it. That is what was done last time.
I really don't want to pull the boat for just a POD gear oil change which is all it needs. I have inspected the anodes and everything else in the water by diving.
Will do the pull out and drain/fill next time.
Rocketman
Postby Rocketman » June 30th, 2022, 3:42 pm
Come to find out, the IPS-C that I have do not have a top port to draw the oil out. You must pull the boat out of the water and drain.
Just FYI.
