over heat
Re: over heat
Just something to check, I replaced my MerCruiser pump housings and impellers this year. The genuine MerCruiser pump kits came with new bolts and washers. While I was assembling the pumps, I noticed the bolts bottomed out before they actually sealed the impeller housing to the pump tightly. I was able to slide a .030 feeler gauge in between the pump and the impeller housing. Probably wouldn't have caught it if I did it on the boat, but I had them at home. Put the original washers back in (they were twice a thick as the new ones) and a nice tight seal. I am sure I would have had a problem if I installed them the way they were.
Hopefully you can find your gremlins soon!
Re: over heat
Do your engines have fresh water rinse ports (a hose on the starb side of the engine with a blue cap on it) on them? If the caps aren't tightened properly, you'll suck air.
Chances are your strainers are Perkos. They use either cork or rubber seals which are easily available. The seal size will will depend on the model (port size) of the strainer.
I'd also like to know which model pump you have. Post engine serial numbers and exact engine model, I want to check the pump model and see if there are any cooling related service bulletins.
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
Re: over heat
Re: over heat
- pepmyster
8.1 Volvo Penta
Re: over heat
3869278
4012121383
2004
Re: over heat
No bulletins stand out for cooling issues and I don't see any incomplete campaigns on that engine. There was warranty work but unrelated.
Here are a few more things I’d be asking considering what you’ve already checked, some of which you may and may not have thought about. It’s a lot I know but a lot are things we usually don't think about. We can only help if questions are answered so we can follow a proper diagnostic process.
- Is your pump an all metal unit or does it have a metal housing but plastic inlet and outlet ports?
- Is the bracket/stay attached to the pump and is the rubber stop lug intact or does it show signs of having overheated?
- Has she ever overheated in the past?
- Any dripping from the pump?
- Is the shaft seal inside the pump in good shape? This is a replaceable part.
- Is the o-ring in the pump installed properly and has it ever been pinched? This would be evident as a section would be flattened instead of round.
- When you replaced the impellers, did you touch the hoses? To confirm, the top hose port is typically the intake and the bottom is the discharge to the engine.
- Are you certain the pump housing isn’t warped? It’s not always noticeable but easily occurs with improper winterizing or running dry.
- Do you have the Neutra-Salt flushing option?
- Are ALL hoses fastened with gear clamps, are there any fastened with crimp type clamps?
- Are you sure of the amount of coolant you have in the engine? Should be close to 26 litres plus the hot water exchanger circuit where applicable.
- Has your coolant been tested? Should be a 50/50 mix. Has the coolant been changed recently? If so, was it added slowly, then engine run between 1000-1500 rpm with NO load for at least 5 minutes? The system is self venting/purging but must be filled properly then topped up as required to the level between the “Min” and “Max” indication marks on the overflow bottle.
- Are there any leaks around the heat exchanger? I believe you have the vertical type. Check for leaks at the hoses, around the top cover, and the top cover bolt.
- Have you verified the temps at the block? Is it in fact overheating when your gauges say it is?
- Is there a steady beeping alarm around 200 deg F?
- How did you winterize the engines? Did you run antifreeze through the strainers so that it passed through the pumps?
- While running, have you sprayed hose connections and the strainer with soap to see if bubbles get sucked in? This is a sure sign that you’re sucking air and may not be noticeable otherwise.
- Have you hooked up a diagnostic tool?
- Anything obvious in the data during an overheat event?
- Have you checked for fault codes yet?
- Engines running properly? Last time tune-ups were done?
The exhaust system can affect cooling also and there’s things to check there but it's getting late so go through the above first.
- pepmyster
8.1 Volvo Penta
Re: over heat
- pepmyster
8.1 Volvo Penta
Re: over heat
Re: over heat
Re: over heat
